Caliper pad pin plug. I_icon_minitimeby Meldrew Today at 8:01 am
» Rear wheel valve stem
Caliper pad pin plug. I_icon_minitimeby GHM-PM Today at 6:43 am
Caliper pad pin plug. I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Caliper pad pin plug. I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Caliper pad pin plug. I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Caliper pad pin plug. I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Caliper pad pin plug. I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Caliper pad pin plug. I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Caliper pad pin plug. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Caliper pad pin plug. I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
3 posters
HORNBLOWER
Number of posts : 171
Caliper pad pin plug. Empty
PostSubject: Caliper pad pin plug.   Caliper pad pin plug. I_icon_minitimeMon Dec 05, 2016 5:10 pm
I have always had problems with the calliper pad pin plugs on my 2003 Silverwing, even though I always put corrosion inhibiting grease all over them, they are always very stiff to undo and I am always worried that one day I won't be able to get them out.
Did the later scooters have the same plug or did they change them for a rubber bung. I know that my Honda Blackbird has the same plugs and I heard that they were changed for rubber ones on the later models.
SilverFeather
Number of posts : 20
Registration date : 2014-08-10
PostSubject: Re: Caliper pad pin plug.   Caliper pad pin plug. I_icon_minitimeTue Dec 06, 2016 12:00 pm
My front brakes have a rubber bung but the rear has a flat head screw. strange, I'm sure you could buy a couple of rubber ones to install.
Although when i do install the pad pin and the metal screw bung i am over zealous with copper grease to prevent seizing and do them up with minimal torque- Had to drill one out and use an easi-out once, so never again
Number of posts : 921
PostSubject: Re: Caliper pad pin plug.   Caliper pad pin plug. I_icon_minitimeTue Dec 06, 2016 12:45 pm
My 2014 Silerwing has a plastic cap covering the pad pin on the front caliper, I just put a new tyre on so checked the brake pads at 22,000 mls. I found vasaline on the pad screw threads works as well as anything.
» Brake Caliper Grease
» rear brake caliper stuck?
» Replacement rear caliper
» Front brake caliper
