| Any experience with Dunlop SX01 tires? | |
+4lloyd193 GHM-PM Easyrider Gustafa 8 posters |
Gustafa Super Scooter Rider
Number of posts : 218 Location : Cordova, TN Points : 3593 Registration date : 2015-10-10
| Subject: Any experience with Dunlop SX01 tires? Tue May 30, 2017 12:16 pm | |
| Walked out to load up my saddlebags and noticed this lovely friend making a home in my rear Pirelli. Luckily it was just embedded in the thick rubber on the edge, no leak and I got home ok. The Swing is sitting until I get new rear rubber, which leads my to my question in the post title. Im kinda tired of the Pirelli Diablo rears, they wear flat and fast. Ive read up the Michelins dont last long, Bridgestones are mediocre, etc Anyone tried the Dunlop SX01's? Any other tire recommendations? I know milage varies, etc but would love to hear some of the latest thoughts, most threads a few years back and maybe theres a tire we havent talked much about yet. Thanks y'all! |
Number of posts : 1013 Age : 74 Location : HI Points : 4344 Registration date : 2015-12-18
| Subject: Re: Any experience with Dunlop SX01 tires? Tue May 30, 2017 1:58 pm | |
| My OEM IRC tire has 10k miles and looks like it can go another 2-3k miles. I think the weather here is less stressful on my tires. The Michelin Power Pure SC dual compound tire seems to make it to 10k and remain round according to some here on this site. I didn't like how the front tire tracked. Especially tar shakes and on concrete roads having water control groves. The font Michelin tires magnified the effects of the groves. Like riding on grated bridges. |
Number of posts : 2621 Age : 72 Location : Bullhead City, AZ Points : 7504 Registration date : 2012-05-17
| Subject: Re: Any experience with Dunlop SX01 tires? Tue May 30, 2017 11:27 pm | |
| I second the IRC. On my second set and they wear like iron. Not the best handling tire I suppose but seem to do fine for my uses. |
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3309 Registration date : 2017-05-13
| Subject: Re: Any experience with Dunlop SX01 tires? Wed May 31, 2017 4:49 pm | |
| Tim, We could have generated some conversation if you hadn't deleted my comment on this tire. Happy motoring lloyd 193.
| Subject: Re: Any experience with Dunlop SX01 tires? Wed May 31, 2017 5:01 pm | |
| - lloyd193 wrote:
- Tim, We could have generated some conversation if you hadn't deleted my comment on this tire. Happy motoring lloyd 193
Huh? |
| Subject: Re: Any experience with Dunlop SX01 tires? Wed May 31, 2017 5:23 pm | |
| That tire is not losing any Nitrogen, That nail is not deep enough to damage any tire Cord, Pull that nail out Squirt some Tube Patch liquid in the Hole, Then finish wearing that tire out. I have installed more than a Thousand Scooter Tires and would never recommend using a dangerous tire. Happy motoring lloyd 193. |
| Subject: Re: Any experience with Dunlop SX01 tires? Wed May 31, 2017 5:31 pm | |
| It has been my experience that the Bridgestone Hoop is consistently the best tire on the Silverwing scooter, Clean that bead area, Always install a new Valve core assembly with that stem support in place on those rear tires. Correctly balanced and pressure maintained, You are in for 10 thousand miles of happy motoring lloyd 193. |
Number of posts : 3313 Age : 85 Points : 9458 Registration date : 2009-08-18
| Subject: Re: Any experience with Dunlop SX01 tires? Wed May 31, 2017 7:50 pm | |
| Ride some miles, then comment----80,000 SilverWing miles and another 60,000 with 2 new Burgman 400's ----same size tire, tells me only Michelin Power Pure SC wears ROUND and lasts about 10,000 miles.
Best thing is also to get rid of that goofy 90 degree valve----designed as easier for fat people to check tires---I use a Honda Part, short/straight valve rated for H rated speeds. Reached from left side---normal gauge and air chuck work ok.
Bridgestone Scooter tires have been problem for me-----3 rears on Reflex, came/flew apart. Bridgestone paid. In addition had Bridgestone rear failure in Japan on Helix----J rated @62 mph,Helix could go about 70 mph downhill/tailwind----Honda never put a higher rated rear on them----had 4 new ones---175,000 miles. After failure just watched speed.
I do own tire work, Ride On balance medium. |
| Subject: Re: Any experience with Dunlop SX01 tires? Wed May 31, 2017 9:14 pm | |
| - lloyd193 wrote:
- It has been my experience that the Bridgestone Hoop is consistently the best tire on the Silverwing scooter, Clean that bead area, Always install a new Valve core assembly with that stem support in place on those rear tires. Correctly balanced and pressure maintained, You are in for 10 thousand miles of happy motoring lloyd 193.
Each to his/her own. If you search on this forum the numbers of Hoops riders that are unhappy with them might surprise you... |
Number of posts : 4217 Location : York, North Yorkshire, England UK Points : 9438 Registration date : 2010-11-16
| Subject: Re: Any experience with Dunlop SX01 tires? Thu Jun 01, 2017 2:24 am | |
| I've had Bridgestone Hoops on every maxi scooter I've had in the last 20 years and mainly they've been fine. The rear tyre started squared off after about 8000 miles on the lardass 650 Burgman, something that didn't happen on lighter 250cc to 400cc maxi's. Last year I had to replace the rear tyre on my Silver Wing last year with a couple of thousand miles legal tread left when it developed a blister just off centre. I could have replaced it with another Bridgestone Hoop but tyre developments moves on and Iwanted a change, I chose to have a Continental ContiMove 365 fitted and replaced the front tyre with a ContiMove too. When the tyres were fitted I also took along a set of shorter Ariete valves stems as I was fed up with the hassle of OE tyre valves on the Silver Wing and every maxi scooter I'd owned previously. The Conti's being all season tyres are kind of weird looking and have a more agressive tread and sipes pattern on them, visually they'd probably have Darksiders reaching for the tissues! After a couple of hundred miles scrubbing them in I installed Puncturesafe. The Conti's seem to hold their recommended pressures for longer than Bridgestone's Hoops and of course with angled valve stems checking them is now a lot easier. |
| Subject: Re: Any experience with Dunlop SX01 tires? Thu Jun 01, 2017 9:16 am | |
| Do you use the Ariete valve on the rear wheel? If so, what about the locater nub for the OE valve stem support?
| Subject: Re: Any experience with Dunlop SX01 tires? Thu Jun 01, 2017 11:46 am | |
- Do you use the Ariete valve on the rear wheel? If so, what about the locater nub for the OE valve stem support?
Tim The Ariete valve assemblies increase the rotating mass, Aggravating the Centrifical forces at work on the tire valve at Highway speeds. Using the lightest assembly, Whether 90 degree with the support or straight is best and safest |
The Ariete valves are on both wheels, they sit low on the wheel rims and the rear one is in the locater nub. It's at an angle pointing forward, and both valves are secured inside the wheel with a lock nut. |
| Subject: Re: Any experience with Dunlop SX01 tires? Thu Jun 01, 2017 11:48 am | |
Tim The Ariete valve assemblies increase the rotating mass, Aggravating the Centrifical forces at work on the tire valve at Highway speeds. Using the lightest assembly, Whether 90 degree with the support, Or straight is best and safest. Over time these aluminum valve assemblies become loose, Because the nut holding them to the rim is inside the rim they cannot be tightened without breaking the bead. Milton Valve Stems manufactures the best High performance valve assemblies, No cheap cast aluminum poor quality assemblies and Indy tested. These will not fail and cause a hi speed blow out. Happy motoring lloyd 193. |
| Subject: Re: Any experience with Dunlop SX01 tires? Thu Jun 01, 2017 1:52 pm | |
| Really, to me they're just nicely made angled tyre valves that are more convenient to use than rubbish OE valves.
But they're also fixed to the rim with a locknut, so it can't bent and be expelled from the rim.
It's an advantage over OE brass valves they need not be replaced every time the tyre is changed.
The angled 'quill' reduces the effect of centrifugal force, which tends to fling the valve outwards in a conventional valve leading to a loss of pressure in the tyre.
Certainly since fitting them with the Conti tyres I'm not having to top up the tyre pressure as often as with Bridgestones.
When I do check the tyre pressures I have far better access for inflation and pressure checks.
Apart from standard fitment angled valves for humble scooters like the Silver Wing, Ariete have them to fit big boys wheels like Marvic, Antera, OZ Racing, and Brembo, so if they're good enough for them they're good enough for me. |
Greysilver Silver Wing Rider
Number of posts : 493 Age : 78 Location : Arizona Points : 4411 Registration date : 2014-04-08
| Subject: Agree Fri Jun 02, 2017 3:46 pm | |
| - GHM-PM wrote:
- I second the IRC. On my second set and they wear like iron. Not the best handling tire I suppose but seem to do fine for my uses.
I am changing tires as we speak and I will go with IRC replacement. I have 11,900 miles on these and they look like another 1000 to go. Longevity is good, repairs are expensive. |
