itoandre Scooter Rider
Number of posts : 9 Age : 56 Location : Florida Points : 2743 Registration date : 2017-06-11
| Subject: What ECU/CDI/ECM/PGM-FI tool do you use? Tue Jun 13, 2017 1:53 am | |
| Hi everyone!
I am searching about the best cost/benefit diagnostic scan tool. What diagnostic scan tool are you using?
Bests |
| Subject: Re: What ECU/CDI/ECM/PGM-FI tool do you use? Tue Jun 13, 2017 3:14 am | |
| No scan tool required. All the ECU/PGM-FI failure codes are read via flash sequences of the FI light. The flash codes are in the FSM (Factory Service Manual).
As someone posted earlier, check eBay for a used manual. In your case any FSM covering 2008 or later will work for you. 2002 to 2007 models did not have the O2 sensor in the exhaust. |
| Subject: Re: What ECU/CDI/ECM/PGM-FI tool do you use? Wed Jun 14, 2017 1:37 am | |
| Thank you again Sir! I will check on ebay. Bests |
