Engine drain bolt I_icon_minitimeby JohnyC Today at 4:39 am
Engine drain bolt I_icon_minitimeby JohnyC Yesterday at 9:04 am
Engine drain bolt I_icon_minitimeby JohnyC Tue Nov 19, 2024 3:42 am
Engine drain bolt I_icon_minitimeby john grinsel Mon Nov 18, 2024 6:50 am
Engine drain bolt I_icon_minitimeby Meldrew Sat Nov 16, 2024 3:37 pm
Engine drain bolt I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 5:05 pm
Engine drain bolt I_icon_minitimeby terryweasely Wed Nov 13, 2024 9:48 pm
Engine drain bolt I_icon_minitimeby AldusFran Mon Nov 11, 2024 8:21 am
Engine drain bolt I_icon_minitimeby xwelder Sat Nov 09, 2024 2:46 pm
Engine drain bolt I_icon_minitimeby landisr Sat Nov 09, 2024 11:46 am
 Engine drain bolt
Engine drain bolt Empty
PostSubject: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 4:24 am
In a rush yesterday I managed to damage the corners of the drain bolt ...
Engine drain bolt 20180610
Bugger, what a silly billy I am (I thought) with nowhere open to buy a replacement, I put it in the bench vice (between blocks of wood so as not to damage the threads) & set to with a coarse flat file,3 or 4 min's later it now fits a 22mm socket, a quick & easy home repair that did'nt need the use of machine tools ...
Engine drain bolt 20180611
Nothing astounding or original about that ^^ my tip, if you damage yours (or it's tight) it can easily be removed by placing a jack with a block of wood on top, under your knuckle bar...
Engine drain bolt 20180612
Light pressure on the jack will prevent the socket 'camming' off.
HTH
Number of posts : 2622
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 7:09 am
Thanks for the tips! This is one delicate area that you can booger up very easily. For myself, I always change my own oil and am extremely careful about the process. I have nightmares of some lube jockey tightening up the plug with an air wrench...AAAAGGGGGHHHH
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 8:30 am
Sadly I've only myself to blame for not being more careful, that & it was me who tightened it last. I messed up, but having the ever present camera it shows a practical way of getting over that particular problem, should it occur to any other member/s
Number of posts : 1999
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 10:22 am
I ordered a spare just in case I mess it up which I have been known to do from time to time even tho I'll never admit it...
So far I've never messed up the drain plug but I guess there's a first time for everything.
Number of posts : 1935
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 11:06 am
thumbs up on the scissor jack idea. So far so good here, remember a 6 point socket works best.
Number of posts : 757
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 12:08 pm
Two ways to trash this piece: using a 12 point socket and not paying attention to righty tighty leftie loosie. I have had issues with this with my previous SWing, thankfully I only needed to learn that lesson once.
Jay.
phils a winger
phils a winger
Number of posts : 179
Registration date : 2014-09-27
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeMon Jun 18, 2018 4:15 pm
tip for anyonw not near a main dealer but have a honda quad bike dealer, the valve cover on i think a 400 quad is the same. Quad dealers are often more helpfull than bike dealers when it comes to going the extra mile.
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeTue Jun 19, 2018 5:52 am
Late but if you can find an OLD drain bolt / I'm told they are heavier in construction, perhaps a bike salvage yard would have one.
bonabob
Number of posts : 13
Registration date : 2017-04-02
PostSubject: Re: Engine drain bolt   Engine drain bolt I_icon_minitimeThu Jul 05, 2018 3:48 pm
Boy does that strike a nerve. My oil bolt looked worse than that. Nothing worked to remove it until I tried an Irwin Tools 53917 Accessories, Impact Bolt Grip 15/16"/24mm 1/2 Dr. It spun it right off. I couldn't find a replacement until i called it an oil CAP. Then it popped up on ebay and amazon. Now I make sure I only use a 6 point socket to tighten and remove it. Lesson learned.
Engine drain bolt
» Oil Drain Bolt Sheared Off
» Transmission Drain Plug and Filler Bolt Torque
» Socket size for oil drain plug???
» Coolant drain plug torque
» Missing drain plug o-ring
