Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
ronslaverda
ronslaverda
Number of posts : 26
Registration date : 2013-10-31
Transmission Drain Plug and Filler Bolt Torque Empty
PostSubject: Transmission Drain Plug and Filler Bolt Torque   Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeSun Mar 30, 2014 9:16 am
Hi,
I have searched in vain and am not able to find these values in any of the topics about changing the transmission oil ( which I have done thanks to the Pictorial)
I just need to know the torque settings now.
Thanks in advance.
Number of posts : 2598
PostSubject: Re: Transmission Drain Plug and Filler Bolt Torque   Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeSun Mar 30, 2014 9:58 am
I would just tighten them good and I never had a problem in 7 years. If someone has their service manual handy maybe there is something in there. I will look later tonight to see if I can find my manual.
ScooterBJ
Number of posts : 170
Registration date : 2013-11-14
PostSubject: Re: Transmission Drain Plug and Filler Bolt Torque   Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeSun Mar 30, 2014 11:04 am
From my manual for 2002-2005 FSC600A: transmission oil check bolt (and) drain bolt are the same, torqued to 13Nm / 1.3 Kgf / 9FtLb.
wingmann
wingmann
Number of posts : 58
Registration date : 2010-08-22
PostSubject: Re: Transmission Drain Plug and Filler Bolt Torque   Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeSun Mar 30, 2014 11:10 am
I got this from my 2002 through 2010 Honda service manual . Transmission oil drain bolt and Transmission oil check bolt / fill bolt .   The  torque is  /  13 n.m   /  1.3 kgf.m  /  9 lbf.ft    hope this helps . Edit I see someone got you the same info when I was writing this up .
ronslaverda
ronslaverda
PostSubject: Thanks   Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeSun Mar 30, 2014 1:14 pm
Thank you for the info.
Regards Ron
Number of posts : 2387
PostSubject: Re: Transmission Drain Plug and Filler Bolt Torque   Transmission Drain Plug and Filler Bolt Torque I_icon_minitimeSun Mar 30, 2014 1:15 pm
Finger tight + 1/4 turn with a 1/4" ratchet is fine, as long as the washer is installed. BTW, the manual says to install a new washer every time. Not necessary, as long as the washer isn't scored or deformed. I don't even bother with a torque wrench for any of the belt housing or rear drive housing bolts. Whatever you do, don't over tighten. It's too easy to strip an aluminum thread in the rear drive housing.
» Coolant drain plug torque
» Drain Plug Torque Spec...
» Oil Drain Bolt Sheared Off
» Engine drain bolt
» Front brake caliper bolt torque
Honda Silver Wing Scooter Forum :: Honda Silver Wing :: "Pictorials" Maintenance-
