| Foot brake | |
+6cotetoi bikerboy terrier Cosmic_Jumper john grinsel Scottish silver 10 posters |
Scottish silver Scooter Rider
Number of posts : 10 Location : Scotland Points : 2217 Registration date : 2018-10-19
| Subject: Foot brake Fri Oct 19, 2018 10:18 am | |
| Hi has anyone fitted a footbrake to a silverwing e.g. one off an MP3 ? Any help tips advice will be much appreciated . Thanks in advance |
Number of posts : 3309 Age : 85 Points : 9435 Registration date : 2009-08-18
| Subject: Re: Foot brake Fri Oct 19, 2018 10:41 am | |
| No in my case...although I love control of the rear brake for low speed control/balance aide.
On SilverWing, effort/cost surely not worth it....ABS/linked/ might have some real problems screwing with the system. |
| Subject: Re: Foot brake Fri Oct 19, 2018 10:50 am | |
| I would just be substituting the hand lever with a foot one so don't see that it would interfere with abs !I may of course be wrong with that assumption. |
| Subject: Re: Foot brake Fri Oct 19, 2018 11:25 am | |
| Silverwing linked brakes---left hand lever works both front and rear. |
| Subject: Re: Foot brake Fri Oct 19, 2018 11:34 am | |
| Subject: Re: Foot brake Fri Oct 19, 2018 11:41 am | |
| Sounds as a bit as if you're trying to perfect sealing wax.
"Kindly come to terms with your ass for it bears you" --Fra Junipero Serra c.1761 |
| Subject: Re: Foot brake Fri Oct 19, 2018 11:43 am | |
| Not really I have a damaged left hand and having a footbrake would make life so much easier for me . |
| Subject: Re: Foot brake Fri Oct 19, 2018 1:51 pm | |
| Knackered left hand? Well then that makes sense. Check the Helix Discussion forum: http://www.slonaker.net/helixforum/index.php Seems to me that, even though the Helix has a foot brake, there have been similar discussions, albeit changing from foot to hand brake, on that forum. So maybe taking cues from those discussions you could reverse engineer the job.
Please keep us informed about your progress. We all benefit from shared information. |
| Subject: Re: Foot brake Fri Oct 19, 2018 1:55 pm | |
| Thanks for that info,will keep forum up to date with what I find out and eventually do. |
terrier Touring Scooter Rider
Number of posts : 302 Age : 75 Location : Northumberland, UK Points : 3707 Registration date : 2015-08-12
| Subject: Re: Foot brake Fri Oct 19, 2018 2:15 pm | |
| - Scottish silver wrote:
- Not really I have a damaged left hand and having a footbrake would make life so much easier for me .
Sorry to hear you have a damaged left hand, but if that is the case what was your reason to choose a scooter with hand operated brakes ? |
| Subject: Re: Foot brake Fri Oct 19, 2018 2:19 pm | |
| I like a silverwing ,so why not try and make it easier for me to ride ?? |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5347 Registration date : 2011-05-12
| Subject: Footbrake Fri Oct 19, 2018 2:49 pm | |
| Have you tried the NABD as they have contacts with folk who can engineer answers to many problems for disabled bikers ? I don't see why scooters should be out of their remit . |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 5040 Registration date : 2013-06-27
| Subject: Re: Foot brake Fri Oct 19, 2018 5:04 pm | |
| I was puzzled but no longer. I hated the foot brake on my Helix. It made me bear weight on my left foot which is numb from nerve damage. It is strong and all but the numbness made me leery of putting weight while holding the rear brake with right foot when starting and at lights, etc. I sold the bike while exploring the hand brake conversion. I am sure there is a fix out there, just a matter of asking at the right window !!!!
Jay |
Number of posts : 1935 Location : Hocking Hills U.S.A. Points : 5335 Registration date : 2016-01-29
| Subject: Re: Foot brake Sat Oct 20, 2018 8:04 am | |
| I'm not sure if it could be done but thinking our cages only have one brake for 4 wheels why not one hand brake for 2 wheels? Tie the S'Wings system together perhaps? with a proportioning valve if needed. |
| Subject: Re: Foot brake Sat Oct 20, 2018 8:39 am | |
| It seems Scottish silver only needs the rear brake ( left hand) to get the bike started. For stopping the front brake is right there. The rear brake lever trips a switch that closes the circuit to the starter. If that switch could be wired closed at all times, problem solved: no need for rear brake lever. I am no mechanic and have no idea how to go about it, but I think this could solve the problem.
Jay.
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 4008 Registration date : 2014-08-24
| Subject: Re: Foot brake Sat Oct 20, 2018 10:44 am | |
| I have an idea that would work, i have a goodrich hose that if connected to the front master cyl via a dual banjo bolt then run direct to the rear caliper both brakes will work from the right lever you might have to block off the centre piston in front caliper. these goodrich pipes came off a racing scoot that i have broken up left lever went direct to rear caliper and right direct to front caliper by passing abs and the small valve thats mounted in the faring frame, just how much braking you going to have front to rear might be an issue |
| Subject: Re: Foot brake Sat Oct 20, 2018 1:07 pm | |
| - cotetoi wrote:
- It seems Scottish silver only needs the rear brake ( left hand) to get the bike started. For stopping the front brake is right there. The rear brake lever trips a switch that closes the circuit to the starter. If that switch could be wired closed at all times, problem solved: no need for rear brake lever.
Jay.
While reworking it any way may affect resale value perhaps just using a micro switch on the right side wired to the left might do it, something that could be removed easily. |
| Subject: Re: Foot brake Sat Oct 20, 2018 1:45 pm | |
| Can I clear something up I don't want to do his just so I can start it up I want it as Honda intended i.e, able to use both brakes if needed .Whatever I do will be easily removable to put bike back to original spec ,same as I do with the left hand switch gear .Thanks for input so far |
| Subject: Re: Foot brake Sat Oct 20, 2018 2:15 pm | |
| This all sounds very interesting in theory, but I'm just wondering what your insurance company will say when you inform them that you've altered the braking system from manufacturers spec to something that's been knocked up in a shed. For many years I worked as a technician designing and fitting various adaptions to cars for disabled people and trying to get some of those approved was mighty difficult. |
| Subject: Re: Foot brake Sat Oct 20, 2018 2:30 pm | |
| As far as any mods I do I always inform them,plus they need to pass a yearly MOT . |
| Subject: Re: Foot brake Sat Oct 20, 2018 8:31 pm | |
| Might be a good idea to start with the MOT folks first. Would be a real bummer to put in all the work and have them reject the MOT. There may have been precedents similar to yours.
Jay. |
steve_h80 Silver Wing Guru
Number of posts : 1035 Location : Teesdale, UK Points : 4205 Registration date : 2016-05-15
| Subject: Re: Foot brake Sun Oct 21, 2018 2:51 pm | |
| As said earlier talk to NABD. Technically I see no difficulty, I would be looking at modifying a spare handbrake and master cylinder onto a small bracket assembly to be operated by a boot. This could be surface mounted onto the footboard and plumbed up. Plenty of people ride modified bikes to manage a disability so there are ways means and ways. |
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4607 Registration date : 2014-11-20
| Subject: Re: Foot brake Mon Oct 22, 2018 3:23 pm | |
| As Steve says above, shouldn't be a great problem to mount a cylinder on the floorboard for foot operation, only point I can think worthy of mention would be, use a master cylinder with remote fluid reservour as the pedal will be lower than the brake union on the fork yoke, using a master cylinder mounted on the floorboard would put the fluid reservour below the highest point of the fluid line & thus making it impossible to fill & bleed air. |
| Foot brake | |
