Battery Charging I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Battery Charging I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Battery Charging I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Battery Charging I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Battery Charging I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Battery Charging I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Battery Charging I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Battery Charging I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Battery Charging I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Battery Charging I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Battery Charging
4 posters
Battery Charging Empty
PostSubject: Battery Charging   Battery Charging I_icon_minitimeMon Jan 04, 2010 7:31 am
Hi y'all. Happy New Year.
My husband has a BMW, with exterior battery charging capability. Given the (brrrr!) cold weather we've been experiencing, and the fact that my battery almost didn't start the other day, I was wondering if anyone has installed something similar on their Swing. I'd appreciate any advice. I have a twelve-volt, but it turns off when I shut off the ignition.
Thanks!
M-
tankyuong
tankyuong
Number of posts : 475
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeMon Jan 04, 2010 9:45 am
Thanks!
M-
I have a $10 float charger from harbor freight attach the alligator clips it comes with and forget about it.
dickie
dickie
Number of posts : 240
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeMon Jan 04, 2010 3:37 pm
Emeskay, I use a charger called "Battery Tender". Durning the winter I swap it between the Gwing and the Swing every couple of weeks. I do get to ride each a couple of times a month even during the cold snaps as we are having now. (it was 18 degrees this morning). I travel for a living and they set dorment for a great deal of time so I use the battery tender most year around. Have a great New Years...Dick
CVan
Number of posts : 11
Registration date : 2012-08-12
PostSubject: Second Battery   Battery Charging I_icon_minitimeMon Oct 01, 2012 8:54 pm
Hello all. I am intending to install a few electrical accessories including a stereo setup from Shark and would like to install another small battery.
I have ordered a universal motorcycle Fuze Block from Wingstuff that has a built in relay to isolate the starting battery, and want to install a small gel cell battery for power to all the electrical accessories.
My question is if anyone knows if the charging system will provide enough power to fully charge both batteries. I don't want to end up with 2 dead batteries if it will not.
Any insight is appreciated, as I am certainly no engineer or mechanic either one. geek
KurtPerthWA
KurtPerthWA
Number of posts : 1711
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeMon Oct 01, 2012 9:08 pm
I use a stainless lighter socket to accept the plug which I have adapted to the charger. The socket is wired directly to the battery so I can plug in any accessory, eg tyre pump etc.
I have a main switch mounted under the tupperware to isolate the earth
( negative) wire from the rest of the scoot while charging the battery, and it also saves the battery when I am not using the scoot for extended periods.
Another benefit of this switch is it is hard to find and makes the electical system dead for security as well.
Pictures in the album somewhere.
Battery Charging
» Battery Charging
» Battery Charging
» charging battery
» Low charging
» Another battery charging question
