Alphawing,
Here is some info on the battery:
For Batteries themsleves the link for the factory battery is
http://www.yuasabatteries.com/battery.asp?bID=B178&vID=401
The other one is:
http://www.yuasabatteries.com/battery.asp?bID=B179&vID=6485
2 batteries fit the Silverwing:
the YTZ12S which is the stock battery with 210 CCA and 11 amp hours
the YTZ14S which will also fit and has 230 CCA and 11.2 amp hours
The batteries are otherwise identical in every way.
Search the web for local or cheap sources of the model you want.
This company seems to have a few alternative batteries also.
Check their cross reference system to find the battery choices for the Silverwing. I think there are 4 choices.
http://www.ebatteriestogo.com/landing_pages/powersport/UBTZ12S.htm
edited to include the below info:
But my question is: How did Dennis get all this info on the SWing but somehow omit the battery info? Could it be a conspiracy?
I am reposting this so see if I can get the info into a text file instead of a spreadsheet:
Oil SG 10W-40 (NOT energy conserving or castor oil)Capacity 2.1/2.3 qt (change with filter)
Oil Filter Honda 15410-MCJ-003, KN204, Walmart ST7317, Purolator Pure One PL14610
Tires Front (29 psi) 120/80-14M/C 58S Bridgestone Hoop B03, IRC SS530F
Rear (39 psi) 150/70-13M/C 64S Bridgestone Hoop B02 IRC SS530R
Spark Plugs NGK CR8EH-9 or DENSO U24FER9
Fuses 30A 15A 10A
Engine Type 582cc liquid-cooled four-stroke parallel-twin Bore and Stroke 72mm x 71.5mm
Compression Ratio 10.2:1
Valve Train DOHC; four valves per cylinder
Carburetion PGM-FI with automatic enricher circuit
Ignition Computer-controlled fully transistorized with electronic advance
Transmission Transmission: Automatic V-Matic belt drive
Suspension Front 41mm hydraulic fork; 4.7 inches travel
Rear Swingarm with dual hydraulic shocks with five-position spring , , preload adjustability; 4.7 inches travel
Brakes Front Single 256mm disc with CBS three-piston caliper Rear Single 240mm disc with CBS twin-piston caliper
Tires Front 120/80-14 Rear 150/70-13
Wheelbase 62.8 inches
Seat Height 29.1 inches
Overall dimensions Length 89.6 inches Width 30.3 inches Height 56.3 inches
Dry Weight 501 pounds
Curb weight 540 pounds
Max Weight Capacity 366 pounds
Fuel 86 octane or higher
Tank Capacity 4.23 gallons, including 0.9 gallon reserve
K & N Air Filter HA-6002
K& N Oil Filter KN-204 Purolator Pure One PL14610
Headlight 12v 55w x2 Size H7 or Sylvania Silverstar H7ST
BASIC MAINTENANCE SCHEDULE
600 Miles Oil and filter. Inspect Engine Idle Speed
4,000 Miles Clean belt case, air cleaner, and crankcase breather. 8,000 Miles Replace spark plugs, oil and filter. Clean belt case, air cleaner, crankcase breather, and oil strainer screen.
12,000 Miles Replace air cleaner. Clean belt case and crankcase breather. Replace brake fluid (or at 2 years).
16,000 Miles Replace spark plugs, oil and filter, and drive belt. Clean belt case, air cleaner, and crankcase breather.
Special Maintenance Notes: Change Oil and Filter every 12 months Replace brake fluid and final drive oil every 2 years Inspect drive belt every 12,000 miles
_________________
>> Dennis
