Not sure if bike is charging battery on the go.  I_icon_minitimeby JohnyC Today at 10:39 am
Not sure if bike is charging battery on the go.  I_icon_minitimeby JohnyC Yesterday at 3:04 pm
Not sure if bike is charging battery on the go.  I_icon_minitimeby JohnyC Tue Nov 19, 2024 9:42 am
Not sure if bike is charging battery on the go.  I_icon_minitimeby john grinsel Mon Nov 18, 2024 12:50 pm
Not sure if bike is charging battery on the go.  I_icon_minitimeby Meldrew Sat Nov 16, 2024 9:37 pm
Not sure if bike is charging battery on the go.  I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 11:05 pm
Not sure if bike is charging battery on the go.  I_icon_minitimeby terryweasely Thu Nov 14, 2024 3:48 am
Not sure if bike is charging battery on the go.  I_icon_minitimeby AldusFran Mon Nov 11, 2024 2:21 pm
Not sure if bike is charging battery on the go.  I_icon_minitimeby xwelder Sat Nov 09, 2024 8:46 pm
Not sure if bike is charging battery on the go.  I_icon_minitimeby landisr Sat Nov 09, 2024 5:46 pm
2 posters
jd70
jd70
Number of posts : 24
Registration date : 2013-09-02
Not sure if bike is charging battery on the go.  Empty
PostSubject: Not sure if bike is charging battery on the go.    Not sure if bike is charging battery on the go.  I_icon_minitimeTue Sep 22, 2015 6:24 pm
2008 600. Not sure if bike is charging battery on the go.
Is there a fuse for this. New battery in about year ago and does not seem to be holding charge.
Is there a fuse chart.
NWSSC
NWSSC
Number of posts : 418
PostSubject: Not sure if bike is charging battery on the go.   Not sure if bike is charging battery on the go.  I_icon_minitimeTue Sep 22, 2015 7:36 pm
Simply put, you need to check the voltage that the alternator is charging. Install your meter (or borrow one) on the battery and see if you have about 14.+ volts at about 2500-3000 rpm.You need this much voltage to have a decent amount of amps going to the battery. Next simplest item would to see if you have a draw on the battery. Next you should take the battery to a scooter or motorcycle repair shop and have them do a brake down test on the battery to see if it has the capacity to hold a charge. Let us know so we all can help. Howard
» Bike not charging battery.
» Battery Charging
» Dead battery ???
» Battery Charging
» charging battery
