stevec Scooter Rider
Number of posts : 27 Age : 67 Location : fordyce ar Points : 5271 Registration date : 2010-07-18
| Subject: charging battery Wed Nov 17, 2010 11:16 am | |
| How many amps do you set battery charger on to charge a silverwing battery |
tankyuong Silver Wing Rider
| Subject: Re: charging battery Wed Nov 17, 2010 12:38 pm | |
jdeereanton Silver Wing Guru
| Subject: Re: charging battery Wed Nov 17, 2010 1:34 pm | |
| Much depends on how quickly you need to have the battery charged.
http://www.battery-chargers.com/charging_instructions.htm
I tend to think that if you are not in a rush it is best to use the lowest setting. The charger I have has a sensing circuit, I don't know what that means, only that it is printed on the box. I've only used the charger once and it did what I needed it to do. |
