Battery Charging I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Battery Charging I_icon_minitimeby JohnyC Today at 11:53 am
Battery Charging I_icon_minitimeby COMick Yesterday at 6:13 pm
Battery Charging I_icon_minitimeby xwelder Yesterday at 12:31 pm
Battery Charging I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Battery Charging I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Battery Charging I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Battery Charging I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Battery Charging I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Battery Charging I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Battery Charging
Cookie
NWSSC
Tommo
8 posters
Tommo
Tommo
Number of posts : 94
Registration date : 2015-10-01
Battery Charging Empty
PostSubject: Battery Charging   Battery Charging I_icon_minitimeTue Oct 13, 2015 2:17 pm
On my old Yamaha XJ600S I had fitted a 12v auxiliary socket direct from the Battery through a fuse, for Mobile Phone charging etc, It also was useful for plugging my trickle charger into to keep Battery topped up.
My question is, can I do the same with the standard 12v socket fitted to the SW?
I am no electrician and want to be sure before I plug charger in.
Tommo.
Number of posts : 4218
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeTue Oct 13, 2015 2:27 pm
I've been using my Optimate 4 plugged into the 12v socket in the left glovebox since I bought my Silver Wing in November 2010.
Tommo
Tommo
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeTue Oct 13, 2015 2:32 pm
Thanks for that, wanted to be sure I wasn't going to burn anything out.
As I mentioned in my post Electrics are not my strong suit.
Cheers. cheers
NWSSC
NWSSC
Number of posts : 418
PostSubject: Battery Charging   Battery Charging I_icon_minitimeTue Oct 13, 2015 7:39 pm
As previously stated you can use this outlet with a trickle charger. It would not be wise to use a larger capacity charger here though.
Howard
Cookie
Cookie
Number of posts : 233
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeWed Oct 14, 2015 3:30 am
Howard's right. I believe the socket is protected by a 2 amp fuse so be careful not to use a charger that goes above this.
Like Meldrew, that's where I plug in my Optimate.
Tommo
Tommo
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeWed Oct 14, 2015 5:25 am
Thanks everybody.
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeThu Oct 15, 2015 11:28 pm
Just remember that the fuse in a circuit is normally sized to protect the wiring not whatever might be plugged into it. It's perfectly safe to go to a lower current fuse if desired but not to a higher current one. One can safely go to a 5A fuse if needed on the 12V socket with no risk.
Gustafa
Gustafa
Number of posts : 218
Registration date : 2015-10-10
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeFri Oct 16, 2015 10:02 am
Following this thread with interest.
Tommo
Tommo
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeSat Oct 17, 2015 10:04 am
I have put a 12v auxiliary socked direct to the battery through an in line fuse, which sits in the luggage compartment under seat, nice and handy for plugging my trickle charger in.
I know that it was said that it was Ok to charge though the factory fitted one in the glove box but, just feel happier with one direct to battery.
Should I carry a fire extinguisher?Laughing
Number of posts : 2625
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeSun Oct 18, 2015 11:09 am
I did much the same thing except I installed the battery tender adaptor direct to battery.  Then purchased a maintainer to 12 volt power outlet adapter at Cyclegear.  That way I can plug in maintainer w/o using battery clips and when on road can plug in outlet and charge cell phone, GPS or camera.  All safely under the seat, out of sight.
Did same thing on Goldwing (sorry Meldrew for mentioning a non Silver Wing) and use same adapter for both.
Here is what I mean by the adapter:
http://www.amazon.com/Battery-Tender-081-0069-8-Cigarette-Disconnect/dp/B0041CDPQO
woodturnertimmers
woodturnertimmers
Number of posts : 11
Registration date : 2015-10-16
PostSubject: Re: Battery Charging   Battery Charging I_icon_minitimeSun Oct 18, 2015 9:03 pm
I'm Getting some good ideas here.
Battery Charging
» Battery Charging
» Bike not charging battery.
» Dead battery ???
» Not sure if bike is charging battery on the go.
» Another battery charging question
