sidco10 Scooter Rider
Number of posts : 27 Location : Liverpool UK Points : 2010 Registration date : 2019-04-19
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | Subject: How to spring balancing head bearings advice Mon Aug 26, 2019 4:32 am | |
| HI all so head bearings installed went with standard ones in the end ..So my question is this, looking at the manual it gives the spring balancing technique in a diagram is that with handle bars fully assembled switch gear mirrors the lot etc or just the stem ? Cheers k |
The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | Subject: Re: How to spring balancing head bearings advice Mon Aug 26, 2019 5:52 am | |
| Hi bud, it's just the stem, otherwise you would be putting stuff on & off until the adjustment was right, that & it says ... If the readings do not fall within limits, readjust the steering top thread. Install the removed parts in reverse order of removal ... in my workshop manual |
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | Subject: Re: How to spring balancing head bearings advice Tue Aug 27, 2019 9:50 am | |
| Hi Bern cheers for the advice I have a manual but was unsure because it says rebuild handle bars etc then the spring test is after that..anyway I managed to do it to torque spec and it is a vast improvement over my spring balance attempts ...cheers again |
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | Subject: Re: How to spring balancing head bearings advice Tue Aug 27, 2019 12:06 pm | |
| Well done bud, now get out & enjoy it while we still have a bit of |
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | Subject: Re: How to spring balancing head bearings advice Wed Aug 28, 2019 7:02 am | |
| Off to Spain and south of France this Sunday ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) |
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | |
![How to spring balancing head bearings advice Empty](https://2img.net/i/empty.gif) | Subject: Re: How to spring balancing head bearings advice Wed Aug 28, 2019 1:22 pm | |
| On quick way to check head bearings is to hold the front brake and rock the bike back and forth a bit. If it's seriously loose you'll feel or hear a slight click or clunk as the bike moves to and fro.
Been wanting to use the word fro for a long time. |
