bleeding breaks help urgent I_icon_minitimeby Hop Today at 7:04 pm
» Rear wheel valve stem
bleeding breaks help urgent I_icon_minitimeby GHM-PM Today at 6:43 am
bleeding breaks help urgent I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
bleeding breaks help urgent I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
bleeding breaks help urgent I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
bleeding breaks help urgent I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
bleeding breaks help urgent I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
bleeding breaks help urgent I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
bleeding breaks help urgent I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
bleeding breaks help urgent I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
bleeding breaks help urgent Empty
PostSubject: bleeding breaks help urgent   bleeding breaks help urgent I_icon_minitimeSun Feb 21, 2010 12:23 pm
i was a fool i fitted hel break lines and now back is great front is weak i have a abs model is there a sevo pump under the front that needs to be bled or have i messed up and need honda service to sort it out please thanks adam i feel such a fool i am so upset
PostSubject: Re: bleeding breaks help urgent   bleeding breaks help urgent I_icon_minitimeSun Feb 21, 2010 7:17 pm
I have never worked on abs breaks.I do know sometimes[on reg.breaks]you can bleed them and bleed them and bleed them again.Then they still take one more time.
It can help to have two people sometimes.But I'm sore you know all this.I'm jest thinking aloud.
Roger
PostSubject: Re: bleeding breaks help urgent   bleeding breaks help urgent I_icon_minitimeMon Feb 22, 2010 5:00 am
You will need some one to help you . Make sure the master cylinder is full .Pump the brake lever a few times and then hold it on ,now the other person opens the bleed port on the caliper to let air out just for a second .Close the port before you release the brake . Do this until no air comes out and the lever feels firm . Or take it to Honda and pay them to do it .
» Honda requires urgent shipment of grease
» Bleeding ABS Brakes
» uncle blinggys breaks at 21,670
» Tip For Bleeding Brakes
» I Need Help With The Brake Bleeding
