It started out with a dragging front brake, and even before I got that sorted the back brake was also dragging,
So I removed both calipers and took out the pistons to remove all brake dust, and give the piston a good cleaning with emery paper.
When I began bleeding the system I had difficulty getting any sort of pressure with the conventional bleed procedure, until I decided to reverse bleed from the bleeder up through the master cylinder with a syringe.
Now the front brake is fine but the back one is not improving, and I notice a squirt of fluid, when I use the lever, coming up from the small hole to the right of the sump feeder hold in the bottom of the master cylinder.
