» Fun times ahead
Smoking Exhaust I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
Smoking Exhaust I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
Smoking Exhaust I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
Smoking Exhaust I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
Smoking Exhaust I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
Smoking Exhaust I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
Smoking Exhaust I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
Smoking Exhaust I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
Smoking Exhaust I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
Smoking Exhaust I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 Smoking Exhaust
cello33
1Wingman1
8 posters
cello33
Number of posts : 150
Registration date : 2018-07-09
Smoking Exhaust Empty
PostSubject: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Feb 05, 2022 6:54 pm
I noticed some smoke out of the exhaust of the swing this morning and wondered if any other inmates have the same issue?
My swing is approaching 40K miles, gets used regulary all year round and I can say i have never noticed this before in 4 years of ownership.
I checked the sparkplugs 4 days ago and started her up briefly  just to check all was in order but then not used her for 3 days  so wonder if this brief 10 second burn was the issue or the fact that I cleaned the irridium  plugs and checked the clearances.
Other then that all is well , she pulls well enough and only needed a slight oil top up last service at around 4K. Saying that she is probably due a oli n filter change so maybe the oil is getting a little thin andfinding its way past  the bores.....
ANy ideas ?
TiA
Number of posts : 1384
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Feb 05, 2022 8:16 pm
Blue smoke or just condensation burning off? If it's not using much oil, then I wouldn't worry about it.
Inmates are restless it's Winter over here.
Number of posts : 572
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Feb 05, 2022 10:21 pm
Check your airbox and/or drain hose for presence of oil, do not overfill oil, middle point between marks is fine, otherwise ride on if no more smoke events. thumbs up
1Wingman1
Number of posts : 126
Registration date : 2013-01-19
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Feb 05, 2022 11:59 pm
Occasionally I see a little blue smoke on cold startup for a few seconds. Uses very little oil. The following link has explanations for different colors of smoke:
https://knowhow.napaonline.com/exhaust-smoke-color-diagnosis-blue-black-white/
Number of posts : 930
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSun Feb 06, 2022 10:55 am
cello33 wrote:
snipped ... I noticed some smoke out of the exhaust of the swing this morning and wondered if any other inmates have the same issue?  Any ideas ? ...
Colour of smoke?
cello33
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSun Feb 06, 2022 11:21 am
Cheers good advice, smoke light white colour.
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSun Feb 06, 2022 11:39 am
White smoke is usually coolant combusting with the gas or more likely, condensation due to temperature differences.  My guess is the "smoke" went away once the scoot warmed up a bit.
Keep an eye on your coolant resevoir level (under front fairing/cowl, upper left hand side ... you'll see a cutout for the coolant bottle and fluid level lines).  Check occasionally for the next few trips out.  if level remains the same, it's likely not the coolant but simply condensation vapour.
Blue smoke is usually oil burning, black smoke usually indicates unburnt fuel ... or your scoot is on fire ... lol
Number of posts : 1604
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSun Feb 06, 2022 2:11 pm
I get white smoke on every start. Only the density differs depending on ambient temperature. It's much less evident on warm days.
Goes away after a short warm up.
cello33
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Mar 19, 2022 4:16 pm
Well the bike is consuming oil as I just went to check the levels and its down past the minimum level , I guess the real question is which part of the engine is worn at 40K miles to allow some oil to seep past into the bores.
Could it be the valve guides or the rings or summit else, the plugs were checked and found to be dry and tan in colour so its not a huge issue but is bound to get worse not better.
Should I keep her or pass her on mmmmmmm i like keeping my bikes but the Swing is a PITA to work on given the bodywork but I guess it could be a opportunity to give her some TLC for all the good times we have had together ......hey honey whats your fancy, a flowed head or a rebore and some new rings !!!
MUCHoldERwingguy
Number of posts : 89
Registration date : 2022-01-29
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Mar 19, 2022 6:49 pm
40K on a Honda engine should be just a nice start on getting broken in, me I'd be sure before I started tearing into things.
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Mar 19, 2022 8:20 pm
Um… You could hook up a vacuum meter and see what it tells you about the condition of the valve guides and/or valve seating. You might also want to do a compression test.
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSat Mar 19, 2022 8:22 pm
Did you check the air cleaner chamber breather/drain hose for presence of oil ??, is on LH side, area in front of centerstand upper pivot point, clear hose with plastic cap.
Is odd your spark plugs are dry, it could also be the "pair system" air injection system sucking oil thru bad Gaskets/O rings on valve cover dowel pins, this go directly to exhaust ports, rare failure, have you had valve cover off ??
40k is nothing on a Silverwing engine.
PostSubject: Re: Smoking Exhaust   Smoking Exhaust I_icon_minitimeSun Mar 20, 2022 10:01 am
Have you checked air filter lately Smoking Exhaust 1f623  ?? Mine looked like this at 10K Surprised
Smoking Exhaust Sw9_211
Smoking Exhaust
» Pretty Sunset in the Chiltern Hills, Buckinghamshire UK
» Exhaust paint
» New exhaust
» Loud Exhaust options
» GPR exhaust
