» Fun times ahead
Light switch iffy I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
Light switch iffy I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
Light switch iffy I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
Light switch iffy I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
Light switch iffy I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
Light switch iffy I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
Light switch iffy I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
Light switch iffy I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
Light switch iffy I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
Light switch iffy I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 Light switch iffy
4 posters
cello33
Number of posts : 150
Registration date : 2018-07-09
Light switch iffy Empty
PostSubject: Light switch iffy   Light switch iffy I_icon_minitimeWed Dec 14, 2022 4:03 pm
Noticed for a long time that when switching from side to main lights on the switchgear that all lights go out briefly before lighting up in the selected mode and wondered if the contacts are about to expire?
Losing headlights at night winter is a serious issue hence the question and wondered if its fixable or needs a new switch? Could be the contacts wearng out after twenty years or slight looseness in the spring if its spring loaded.
We have another 14 weeks of winter and another 120 hrs of riding for me so time for some PM could be nigh......
Number of posts : 1604
PostSubject: Re: Light switch iffy   Light switch iffy I_icon_minitimeThu Dec 15, 2022 4:28 am
If you do a search for 'headlight switch - an insight' you'll see that the switch is spring loaded. The problem could be in there, but if it is the switch itself, it's easy to have a look and maybe clean it up.
Number of posts : 2616
PostSubject: Re: Light switch iffy   Light switch iffy I_icon_minitimeThu Dec 15, 2022 6:45 am
From time to time my switchgear gets a bit sticky. I use the following, easy to use and works for quite a while. This may not be what you need but helps me. Good luck!
https://www.walmart.com/ip/CRC-Electronic-Cleaner-Quick-Dry-for-Sensitive-Electronics-11-oz/16817418?athbdg=L1100
Number of posts : 1998
PostSubject: Re: Light switch iffy   Light switch iffy I_icon_minitimeThu Dec 15, 2022 5:16 pm
I use the same thing as Glenn only I got mine from O'Reilly Auto Parts store because I was having trouble with the dash light dimmer switch in my pickup. It worked great for that and I'm sure it will work great for the SWing also.
cello33
PostSubject: Re: Light switch iffy   Light switch iffy I_icon_minitimeWed Dec 21, 2022 7:17 pm
Cleaned the switch and although it still cuts out briefly , it maybe in the design as the one contact switches to the other , from side lights to full so not actually a issue.
In dong this I also noticed the throttle action is a little on the rough side as you wind on no throttle to 20% , almost like the edges of the cables are rubbing on the edge of summit, again not a issue as such just not as smooth as maybe it should be .....oil as made no difference and the throttle looks clean with no dirt anywhere.
Light switch iffy
» UNDERSEAT LIGHT SWITCH
» Trunk light switch.
» Under seat light and courtesy switch
» Rear brake light switch.
» rear brake light switch
