| Hard Starting | |
+8model28a cotetoi jmaslak Mudnman Cosmic_Jumper tinman DennisB oltxredneck 12 posters |
oltxredneck Scooter Rider
Number of posts : 24 Location : Longview, Texas Points : 4053 Registration date : 2013-09-17
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Hard Starting Wed Apr 16, 2014 12:28 pm | |
| Intermittently I have a very hard time starting my SW when it's off the center stand. No matter how hard I pull in the left brake handle it won't start. I kick the side stand to ensure it's up properly, still no help. Sometimes I roll it around, but to no avail. I have sprayed the left handlebar control switch with electronic cleaner, makes no difference. Any ideas? |
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed Apr 16, 2014 12:35 pm | |
| Hello,
What year is your scooter?
Some people have a problem with the Fuel Pressure Regulator (FPR) on the older bikes. Worth looking into. |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6055 Registration date : 2011-11-29
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed Apr 16, 2014 12:37 pm | |
| Try bypassing side stand switch you might have a dirty connection ,broken wire in the brake switch they are known to fail listen for 2 clicks on the lever. |
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed Apr 16, 2014 12:59 pm | |
| Is it that it cranks but won't fire up, or that it won't even crank?
If it cranks but wont fire, try holding the throttle wide open when cranking. That will help clear a 'flooded' engine. And as Dennis mentioned a faulty FPR could easily contribute to that problem.
If the side stand switch were the problem then the engine wouldn't crank IIRC.
Mudnman Super Scooter Rider
Number of posts : 218 Location : Florida Points : 4131 Registration date : 2014-01-15
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed Apr 16, 2014 3:23 pm | |
That statement suggests its not turning over.
How often does the side stand switch go bad? |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4735 Registration date : 2012-06-15
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed Apr 16, 2014 8:01 pm | |
| If the side stand switch was bad, the engine would tend to cut out once running. |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 4989 Registration date : 2013-06-27
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Mon Apr 21, 2014 1:18 pm | |
| Try blipping the throttle ever so slightly before firing. I was having similar issues, then tried this trick. It worked for me. I don't have any technical savvy so I don't know exactly what it does. I just tried because it works in fuel injected cars. Just a touch of throttle, not a full crank-up. |
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed May 14, 2014 10:36 am | |
| - DennisB wrote:
- What year is your scooter?
it is a 2008. To clarify this problem when side stand and center are up and I am sitting on it, ignition on, left brake lever pulled in hard, hit starter button no response.
Last edited by Colin B on Wed May 14, 2014 4:47 pm; edited 1 time in total (Reason for editing : To correct format error - Colin B) |
![model28a](https://2img.net/u/3413/63/00/33/avatars/494-23.jpg)
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7483 Registration date : 2010-02-03
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Wed May 14, 2014 4:42 pm | |
| Is the brake light coming on when the left brake lever is pulled in? Do you hear two clicks when left brake lever is pulled in? |
uffbros Scooter Rider
Number of posts : 11 Location : Duncansville,Pa Points : 3776 Registration date : 2014-05-25
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Sun May 25, 2014 8:57 pm | |
| Just got a 2004 Silverwing Wed and I have the same problem. I have to squeeze both front and rear brakes and then it starts. |
![Mike from NS](https://2img.net/u/3413/63/00/33/avatars/3151-31.jpg)
Number of posts : 462 Age : 71 Location : Nova Scotia Points : 4522 Registration date : 2013-09-12
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Sun May 25, 2014 9:05 pm | |
| Faulty starter switch ...or lose wire connections? Go for the simple solution first. Both brake levers have an effect? The rear lever is the only one linked in the starting sequence. |
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Sun May 25, 2014 9:21 pm | |
| Well as long as it starts by doing what I mentioned above I'll leave it at that. If that one day doesn't work I'll have to get it to a garage I guess. |
Colin B Silver Wing Expert
![Colin B](https://2img.net/u/3413/63/00/33/avatars/2778-53.jpg)
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4837 Registration date : 2013-03-20
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Mon May 26, 2014 3:36 am | |
| "Sod's Law" states that it will completely fail one cold, rainy night, when you are in the middle of nowhere! |
jcctx Scooter Rider
Number of posts : 8 Location : Henderson county, TX Points : 3827 Registration date : 2014-04-03
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Mon May 26, 2014 9:14 am | |
| I have the same issue (see post about left handle bar micro-switch). I helped mine by "tweeking" the switch action bar a bit with needle nose pliers. Now a hard squeeze will almost always bring it to life. |
![Hard Starting Empty](https://2img.net/i/empty.gif) | Subject: Re: Hard Starting Mon May 26, 2014 4:58 pm | |
| Even when new the Silverwing takes a hard squeeze on the left lever to start. |
| Hard Starting | |
