The vibrations have now been sorted it was the front wheel out of balance dont know who balanced before but I took the weights of.Jacked her up took the front brake caliper of so that the wheel could turn free and then span a few time to watch the heavy point which was always the tyre valve at the bottom.So 180 degrees above this I marked the tyre and started adding some of the weights on each side of the wheel.Until the wheel could be in any position an stay in place ie not roll.whent out for test ride 110 no wheel wobble.cheers all ride safe
