Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby MikeO Thu Nov 14, 2024 6:23 pm
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
tankyuong
tankyuong
tankyuong
Number of posts : 475
Is $31 high for mounting and balancing a wheel?(carry in) Empty
PostSubject: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 2:19 pm
Just had my tire mounted yesterday, they sure added a lot of lead weights.
Number of posts : 2778
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 2:58 pm
That's not a bad price so long they did a good job.
You know it's aways a good idea to keep the speed down for the first 100 miles when you get a new tire installed.
Let use know if your new tire works OK.
tankyuong
tankyuong
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 3:35 pm
how slow should I go, is that for bead seating purpose?
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 3:45 pm
Just keep it under 60 MPH for the first 100 miles.
joncallihan
Number of posts : 1025
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 4:33 pm
If they added a lot of lead weights, insure the yellow/white dot on the side wall is at the stem. I've never had a tire mounted correctly with more than one or two small weights.
http://www.joncallihan.com
forgitaboutut
Number of posts : 55
Registration date : 2009-04-03
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 8:51 pm
not so much the speed! carefull on turns!
tire has a coating on it..can be slick!
I went down in a turn once at slow speed!
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 9:41 pm
This is a picture of what that mark looks like on a new hoop.
Is $31 high for mounting and balancing a wheel?(carry in) Hoop_d10
matthew
matthew
Number of posts : 361
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeWed Aug 12, 2009 10:01 pm
I pay $35 for either front or rear.
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeThu Aug 13, 2009 12:16 am
I just brought my front and rear rims and old tires in for the local Honda shop to replace them with new tires. They charged me $24 per tire to mount and balance them.
I read that the reason you are suppose to take it easy on turns and breaking for the first 100 miles. It said the tires are
coated with a mold release to make it easy to come out of the mold. Also your going from a old worn out tire with low tread to a new tire with full tread and it may take a while to get used to the full tread. Until that release is worn off you should ride a little Conservative.
Paul
tankyuong
tankyuong
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeThu Aug 13, 2009 12:40 am
I went through 10 miles of gravel today, maybe that would help take the coating off.
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeThu Aug 13, 2009 12:46 am
If the tires or the road are wet ... and you push the tire too hard you will quickly know.
tankyuong
tankyuong
PostSubject: Re: Is $31 high for mounting and balancing a wheel?(carry in)   Is $31 high for mounting and balancing a wheel?(carry in) I_icon_minitimeThu Aug 13, 2009 12:56 am
They also wrote down $3 disposal fee in the price
» Do you remove the rotor when you carry in your wheel to get tires replaced?
» darkside tire, front wheel wobble at high speed (80+mph)
» How Do You Carry Spare gas
» Anyone ever carry a silverwing on the back of an rv?
» Tool Bag Advise To Carry
