| Brake pad wear | |
damian30 Scooter Rider
Number of posts : 12 Age : 48 Location : North London Points : 3950 Registration date : 2014-02-18
| Subject: Brake pad wear Wed Mar 25, 2015 6:48 pm | |
| Hi guys, How many miles should I expect to get out of a set of brake pads? When it comes to mechanical stuff I'm as green as Kermit so I don't know the type of pad my garage uses I'm afraid! I believe I got less than 3000 miles out of my last set, but they could have been damaged in an accident I had rather than worn out. I ran into a London black cab at about 10-15mph with both brakes pulled and the bike then fell on its right hand side. The front wheel was instantly sluggish and rubbing. Got the bike back after 3mths only to find the rear acting the same. A friend pointed out the lower pad was sticking to the disc and the higher pad had daylight between it and the disc. Got them changed today and my mechanic said the rear was down to the metal no way that should have been the case! Could it be from the accident? |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5566 Registration date : 2012-04-29
| Subject: Re: Brake pad wear Wed Mar 25, 2015 7:18 pm | |
| Yes in my opinion you have a problem. My swing got around 25k klms on it now and the original brakes are still in tip top shape. Obviously it depends on rider and riding terrain but i think you would easily get more than 3k miles out of a set of brake pads! Maybe you're riding the brakes continuously! Are the brake discs smooth or do they have ridges? Are you getting a shimmy while braking? After your accident the brake caliper (the part that holds the brake pads) could be seized and not allowing the pads to properly release! |
| Subject: Re: Brake pad wear Wed Mar 25, 2015 7:22 pm | |
| Thanks, I figured something wasn't right! Lol They seemed happy with the calipers and discs today so don't think that's the issue. Definitely don't ride the brakes constantly but did notice a strong judder from the back brake just before the collision. Will get them to go over it all properly when it goes in next |
NWSSC Silver Wing Rider
| Subject: Brake pad wear Wed Mar 25, 2015 11:27 pm | |
| Brake pad wear and fuel mileage are usually related to driving habits and of course you could have some mechanical problem.I replaced the front pads on my 06 S/W at 45,000 miles and my rear are still OK at 50,000 miles. Yes I do a lot of highway riding.That being said I feel you have some mechanical problems to address. It is important to find a good mechanic you can trust and stay with them. Generally speaking you should not see day lite between the brake pad and the rotor. If the pad is not in complete contact (contacting at a angle) this is a problem. There is the possibly of a stuck piston in the caliper.The brake fluid will move both pistons at the same rate but if one piston is stuck all the fluid will go to the other piston and cause the the pad to wear at a angle. This could be part but not all of your brake problem. What year is your S/W and mileage. Are you the original owner? Keep us posted. Howard NWSSC |
| Subject: Re: Brake pad wear Wed Mar 25, 2015 11:48 pm | |
| In 54,400+ miles I've replaced the front pads two times and the rear one time. The first time I replaced the front pads I used EBC brake pads and they ate up my disk. I replaced the disk and pads with genuine Honda parts and they have held up great. I only use genuine Honda pads now. I would have to look through my records to see what the mileage was when I put the pads on but they still look as good as new. |
| Subject: Re: Brake pad wear Thu Mar 26, 2015 4:40 am | |
| It's a 2012 model, just over 14000m on the clock and I have had it from New. This is the 3rd time I've had them changed now and never had such wear, including on a piaggio x8 400 and another silverwing |
| Subject: Re: Brake pad wear Thu Mar 26, 2015 10:49 am | |
| From the vantage of 95,000 miles on my '03 SW I'd say that you've got a stuck or binding piston in the brake caliper. You should either have it rebuilt or rebuild it yourself. It is not a difficult DIY job, and the pistons and seals for the caliper are not that expensive. There are several "How To" YouTube videos for refurbishing brake calipers. If you are squeamish about the job then you should have a shop do it.
| Subject: Brake pad wear Thu Mar 26, 2015 1:29 pm | |
| Like most repairs on the S/W when you have done them they are not that difficult,but. But a word of caution.Removing a stuck piston is one thing but air trapped in the system can be time consuming.Try to minimize the loss of brake fluid. Capping off the line to the caliper with a piece of tubing is fairly easy.Do not let the brake reservoir run out of fluid.It is easier for two people to bleed the system. Be patient. Howard NWSSC |
| Brake pad wear | |
