Battery compartment size? I_icon_minitimeby sonuvabug Today at 4:19 pm
Battery compartment size? I_icon_minitimeby sonuvabug Today at 4:17 pm
Battery compartment size? I_icon_minitimeby sonuvabug Today at 4:06 pm
Battery compartment size? I_icon_minitimeby JohnyC Yesterday at 10:04 am
Battery compartment size? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Battery compartment size? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Battery compartment size? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Battery compartment size? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Battery compartment size? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Battery compartment size? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Siataukreg
SteveSilverWing
razorback
Tommo
vmaximus
Ofer Rothmann
11 posters
Ofer Rothmann
Ofer Rothmann
Number of posts : 48
Registration date : 2013-05-06
Battery compartment size? Empty
PostSubject: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 4:51 am
Hi,
Does anyone know the size of the battery compartment, I want to replace my battery to a larger one.
Thanks,
Ofer Rothmann
vmaximus
Number of posts : 133
Registration date : 2011-04-15
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 5:56 am
Is it not easier to just measure the one that's fitted on your own scooter or measure the size of the battery.
Tommo
Tommo
Number of posts : 94
Registration date : 2015-10-01
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 5:58 am
Have a search through the threads re battery, some one had put a number of a battery with a higher output on.
thought I had written the number somewhere, but can't find it.
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 6:02 am
Wink I won't be near my SilverWing in the next 3 days and I want to mail order a new battery.
[Tommo] thanks for the input, I already saw this thread but we have a special price on a different type of battery.
Thanks,
Ofer
Tommo
Tommo
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 6:08 am
Found number, Yuasa YTZ14.
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 6:12 am
Thanks, I need the maximum size of battery I can place there.
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeWed Feb 03, 2016 9:07 am
The Yuasa YTZ-14 battery which Tommo mentions is a larger capacity and an upgrade over the OEM YTZ-12 battery. They are both the same physical dimension; 150mm x 87mm x 110mm. Google is your friend.
razorback
razorback
Number of posts : 42
Registration date : 2016-01-31
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeTue Mar 01, 2016 9:16 am
what i did was simply add a 2nd larger battery dry cell, and dropped in the storage area next to current side mount for the batt, and keept the old batt as a back up
SteveSilverWing
SteveSilverWing
Registration date : 2015-04-17
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeSat Jun 24, 2017 7:09 pm
I've got a 2013 FSC600/A Silver Wing and need to place the battery.
My Yuasa YUAM7212A YTZ12S battery (came new with bike) needs to be replaced -- won't hold a charge for more than 24 hours. Found it easily enough on Amazon.com but the casing size doesn't match.  My dead battery measures approx. 5.9 x 3.4 x 4.33 inches while the Amazon battery (same tech specs) measures 6.8 x 5 x 3.8 inches.  Does anyone know how, or where, I can get a battery that will absolutely fit?
I initially bought a battery charger: trickle 6/12v automatic at 2 amp. It charged beautifully and turned the engine over in a snap. Several hours later, the starter hesitated to turn the engine over. It was time I bought a battery charger anyways...
Thanks for any help/advice you may have to offer.
Siataukreg
Siataukreg
Number of posts : 222
Registration date : 2014-08-24
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeSat Jun 24, 2017 7:42 pm
I have a second battery its in the luggage compartment below the original battery only mine is connected via Anderson plug so both are in constant use. I have also done the same thing with my Aprilia mana 850 gt battery is where the fuel tank normally is, on this bike its a helmet compartment I have the second battery in there next to the battery compartment again connected via Anderson plug tank is under passenger seat
Flyingpanman
Flyingpanman
Number of posts : 237
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeSat Jun 24, 2017 8:40 pm
You could investigate Lithium batteries? Less than a third of the weight, usually smaller in size to normal wet batteries and are only slightly more expensive.
I've had one on my Suzuki V-Strom 1000 for more than a year and it has been great.
Number of posts : 1935
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeSat Jun 24, 2017 8:46 pm
Lithium battery in mine now, cranks very well, it's almost twice the CCA of the one it replaced. 99 bucks from Amazon with free shipping.
Number of posts : 1999
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeMon Jun 26, 2017 4:22 am
I've had a Battery Tender Lithium battery in mine for about 3 years now with no problems. It has all the power I want/need and is smaller and lighter than a lead acid battery. It comes with dense foam spacers to take up the extra space left in the compartment because of its smaller size.
Battery compartment size? New_ba10
Battery compartment size? New_ba11
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeMon Jun 26, 2017 8:32 am
My Lithium was sized for the compartment no need for any spacers, weight about 3 1/2 lbs. CCA double the wet cell.
Thebreen
Number of posts : 78
Registration date : 2011-09-15
PostSubject: Re: Battery compartment size?   Battery compartment size? I_icon_minitimeTue Jun 27, 2017 2:26 pm
still on my original (bought new from dealer September 2011). its about done though (if i leave it parked more than 2 weeks it has to be charged).
I have a portable LiIon jumpstart battery that i now carry in the bike just in case.
there is also the SHORAI LFX battery (very expensive and very light for equivalent power delivery compared to standard Sealed Lead Acid battery and even LiIon).
what ever you get be sure to the battery terminals are in the same place as original or the cables may not reach.
» Yellow wire in battery compartment?
» Battery size on a 2002
» Bolt size for 2009 Swing battery cover
» Broken left compartment latch
» Right Storage Compartment Latch
