Latest topics | » It's that time of year again. by MikeO Thu Nov 14, 2024 6:23 pm
» 85 and new bike second on experience by POCAHONTAS Thu Nov 14, 2024 6:05 pm
» fsc600 vs fjs600 rear shocks by terryweasely Wed Nov 13, 2024 10:48 pm
» Looking for info/Potentially selling 2004 Silverwing. by AldusFran Mon Nov 11, 2024 9:21 am
» 2003 ABS Silverwing re fresh by xwelder Sat Nov 09, 2024 3:46 pm
» Rarity for Honda, catastrophic engine failure at 35k miles by landisr Sat Nov 09, 2024 12:46 pm
» Welcome to New Admin by Dale N. Thu Nov 07, 2024 10:07 pm
» New owner…finally by Erdoc48 Thu Nov 07, 2024 8:24 am
» complete engine and transmission for sale in uk by Siataukreg Thu Nov 07, 2024 3:45 am
» Parting out 2004 Silverwing 600 by kbcmdba Mon Nov 04, 2024 7:56 pm
| Hypothetical Starting Issue | |
cello33 Maxi-Scooter Rider
Number of posts : 150 Location : uk Points : 2526 Registration date : 2018-07-09
| Subject: Hypothetical Starting Issue Thu May 26, 2022 6:24 pm | |
| So lets say you go out to your wing put the key in turn on the igni press the button and nada!
Yes Nada , no turn over from the motor , could it be the button the wiring / fuse or the starter motor itself, is there anyway to get her started so you can continue your trip......
I think I now the answer but maybe someone found a ingenius way of getting the motor turning. I mean my swinger is 20 years young and has served me brilliantly but I,m paranoid that the starter motor , gear or summit else could pack up and leave me high n dry.
| | | Terry Smith Silver Wing Rider
Number of posts : 403 Age : 60 Location : Auckland, New Zealand Points : 2138 Registration date : 2020-03-11
| Subject: Re: Hypothetical Starting Issue Thu May 26, 2022 6:53 pm | |
| Well there's no way to bump start as the bike has a centrifugal clutch.
My first step would be to get a jump start off a handy car battery.
Jumping the starter solenoid would not be terribly difficult with a set of jump cables, and that also bypasses the starter button. |
| | | dovahkiin Scooter Rider
Number of posts : 58 Location : SG Points : 1006 Registration date : 2022-05-09
| Subject: Re: Hypothetical Starting Issue Thu May 26, 2022 11:34 pm | |
| - cello33 wrote:
- So lets say you go out to your wing put the key in turn on the igni press the button and nada!
If you press the ignition button and your headlights dim and you hear a click, it probably means that the carbon holder brush in your starter motor needs to be replaced. My workaround prior to replacing the carbon holder brush was to get a T-type socket wrench and hammered where the start motor/top part of the engine would be at. Don't understand the science behind hammering the engine, but it works like a charm to get it started up. This would have to involve you removing the left side of your Swing's pillion foot peg though. |
Number of posts : 1036 Location : Teesdale, UK Points : 4224 Registration date : 2016-05-15
| Subject: Re: Hypothetical Starting Issue Fri May 27, 2022 3:22 am | |
| It could anything but if the battery was good (lights on, fuel pump ok) and it was just the motor not turning over my first call would be the left lever interlock switch, the sidestand switch and the right switch cluster. All are exposed to the weather and likely to gum up. If you're worried about the battery carry a small boost starter under the seat, and learn how to use it. |
| | | GHM-PM Site Admin
Number of posts : 2621 Age : 72 Location : Bullhead City, AZ Points : 7505 Registration date : 2012-05-17
| Subject: Re: Hypothetical Starting Issue Sat May 28, 2022 9:17 pm | |
| As Steve mentions above a likely suspect would be the start interlock switch on the left handlebar. It controls both the starter and the rear brake light switch. Mine went out recently (the brake portion) so I ordered a new switch and changed it out; very easy. I then as you, was worried about being stranded so kept the old switch as the start circuit was fine... With that and a Phillips screwdriver should be good.
I also change my battery every 2-3 years max as they are fairly cheap and I hate to risk a dead one. |
| | | genius149 Scooter Rider
Number of posts : 9 Location : East Kent, UK Points : 928 Registration date : 2022-05-16
| Subject: Re: Hypothetical Starting Issue Sun May 29, 2022 1:02 pm | |
| Sorry for the obvious question but you are making sure that there is a second click when you squeeze the brake lever? It confused the hell out of me when I got mine a few weeks ago! |
