| bike won't start after turning it on and off | |
+4jdduvall john grinsel Erdoc48 XDM© 8 posters |
XDM© Maxi-Scooter Rider
![XDM©](https://2img.net/u/3413/63/00/33/avatars/5346-16.jpg)
Number of posts : 125 Location : Philly, Pennsylvania Points : 1962 Registration date : 2019-10-20
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: bike won't start after turning it on and off Fri May 24, 2024 3:14 pm | |
| So I started my bike and normal to get to work and it was fine but then I noticed that my license plate was hanging I turned off the bike so I can open my glove compartments and when I try to turn the bike back on it just wouldn't turn over. No spinning of the starter no nothing but the clicking noise of the headlight turning on and off when I try to ignite. Batteries completely normal as well at 14.5 volts and out of curiosity tried jumping it and it made no difference anyway. I checked all the wiring it seems mostly okay for what I can see on the outside no internal inspection yet. I checked all of the fuses and they all seem okay. The fuel pump makes its a little normal whine when I turn the key. I'm wondering if the starter motor is damaged. What do you think? |
Erdoc48 Touring Scooter Rider
Number of posts : 373 Age : 60 Location : Myrtle Beach, SC Points : 1218 Registration date : 2022-05-31
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Fri May 24, 2024 3:25 pm | |
| Any chance it is a problem with the left brake handle switch, which does not allow your bike to start? I assume it would be unusual to have it run and then not but I would probably start with some thing easier before assuming it is the starter motor. |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Fri May 24, 2024 3:38 pm | |
| - Erdoc48 wrote:
- Any chance it is a problem with the left brake handle switch, which does not allow your bike to start? I assume it would be unusual to have it run and then not but I would probably start with some thing easier before assuming it is the starter motor.
I'm using aftermarket brake handles so that that removes that limitation. (Maybe I should check that wireing On the handlebar left brake) I did splice the wires together a long time back so that I can use regular brake handles. |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sat May 25, 2024 4:30 pm | |
| After leaving it alone for a day and doing absolutely nothing with it I came back today and it started up like clockwork as it always does. Turned it off waited a second turned it back on and it works just fine turned it off again and waited a little longer and now it doesn't start up again but the starter engine sounds completely normal and fine I wonder what it could be? I checked the wiring near the handlebar and everything looks fine up there. The clicking noise that it makes is near the middle part of the bike.
https://i.servimg.com/u/f32/20/12/59/48/pxl_2014.jpg
https://i.servimg.com/u/f32/20/12/59/48/pxl_2013.jpg
This solenoid is clicking, but the fuse is fine |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sat May 25, 2024 6:16 pm | |
| battery age? charging system? |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sat May 25, 2024 6:24 pm | |
| - john grinsel wrote:
- battery age? charging system?
Brand new lithium ion battery (NLP14) installed this February, stock charging system I guess? |
jdduvall Scooter Rider
Number of posts : 7 Age : 60 Location : Kokomo, Indiana Points : 127 Registration date : 2024-05-13
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sat May 25, 2024 9:40 pm | |
| Check the kill switch been there done that. |
![Dale N.](https://2img.net/u/3413/63/00/33/avatars/3360-93.jpg)
Number of posts : 1995 Age : 78 Location : Princeton, MN Points : 5996 Registration date : 2014-02-13
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sun May 26, 2024 12:59 am | |
| Just a thought on my end. Could it be the kickstand switch? |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sun May 26, 2024 3:46 am | |
| Sorry if I missed this point in the above but; is the clicking noise the starter motor solenoid struggling to make contact? |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sun May 26, 2024 6:07 pm | |
| I replaced the solenoid today and the issue still persist so I guess it wasn't that, I also checked the kickstand protection circuit and it's working fine if I move it the clicking stops in the bike will not even attempt to turn on same thing with the kill switch circuit which is all operational. All fuses seem to be okay. I heard of someone taking a soft rubber mallet and tapping near the starter motor to see if it's seizing up and for that person he was able to detect that the starter engine was failing |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sun May 26, 2024 6:36 pm | |
| I just thought of this. What about the cable connections to the battery and starter- sometimes the best fix is the cheap (or free) one. If not nice and tight, you may not have enough current flow to trigger the starter. |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Sun May 26, 2024 6:53 pm | |
| Welp as that YouTube video said, I just took apart the bike down to the and tapped the engine area with a rubber mallet and it started right up. Oh boy. Must I replace it or might it need liberating?
Hitting this also let's it start too https://i.servimg.com/u/f32/20/12/59/48/pxl_2015.jpg |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Mon May 27, 2024 6:29 am | |
| If you tapped it with a mallet and it starts, it indicates the likelihood of a bad electrical connection to the starter if under other circumstances it starts and runs well. Before tearing it all down and possibly replacing parts that don’t need replacing, start with the simpler stuff first- check your cable connections, even taking them off, shooting some CRC QD or equivalent electrical contact cleaner spray on them to remove oxidation, and reconnect. It may need a starter I guess, but I would say this is less likely for a Honda. How many miles on your Silverwing? |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Mon May 27, 2024 3:59 pm | |
| - Erdoc48 wrote:
- If you tapped it with a mallet and it starts, it indicates the likelihood of a bad electrical connection to the starter if under other circumstances it starts and runs well. Before tearing it all down and possibly replacing parts that don’t need replacing, start with the simpler stuff first- check your cable connections, even taking them off, shooting some CRC QD or equivalent electrical contact cleaner spray on them to remove oxidation, and reconnect. It may need a starter I guess, but I would say this is less likely for a Honda. How many miles on your Silverwing?
I have about 25,000 mi on it |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Fri May 31, 2024 5:04 pm | |
| Should I try oiling it first before buying a new one or should I just replace it and be done with it? |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Fri May 31, 2024 6:46 pm | |
| Try oiling what? More investigation is needed before just ordering and replacing parts. Just friendly advice, that’s all. |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Fri May 31, 2024 7:09 pm | |
| - Erdoc48 wrote:
- Try oiling what? More investigation is needed before just ordering and replacing parts. Just friendly advice, that’s all.
I don't know, I never got that deep In the bike before. I don't know what I'm looking for or at but I see the motor online. I assume there's gears that might need lubricate that could be stuck |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Thu Jul 18, 2024 2:56 pm | |
| ![bike won't start after turning it on and off Pxl_2016](https://i.servimg.com/u/f32/20/12/59/48/pxl_2016.jpg) Isn't this thing the starter? It's to the left of the radiator. |
JohnyC Touring Scooter Rider
![JohnyC](https://2img.net/u/3413/63/00/33/avatars/6268-1.jpg)
Number of posts : 346 Age : 71 Location : Bristol, UK Points : 979 Registration date : 2022-12-23
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Thu Jul 18, 2024 3:55 pm | |
| Hi XDM.
That is a picture of your coil.
Couple of questions.. when trying to start, does the bike just sit there or(are you squeezing the rear brake hard enough to operate both micro switches) does the engine just spin and spin without firing. more info please. Awaiting your response.
Be safe, be seen! |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Thu Jul 18, 2024 4:02 pm | |
| - JohnyC wrote:
- Hi XDM.
Be safe, be seen! What coil is that and what purpose does it serve? Also (against better judgment) I have the brake startup requirement bypassed because I installed aftermarket brake handles. This bike will start regardless of my brakes being pressed or not. The wiring to that is fine as well and working. If something was wrong with that I would not hear a click from the solenoid if it weren't working at all. That's serious tested because if I have the emergency cut off engaged nothing happens as well which would be the same thing that would happen if the bypass or holding the brakes weren't working. |
zrx212 Silver Wing Expert
Number of posts : 553 Age : 65 Location : Ocala, FL Points : 1922 Registration date : 2020-12-26
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Thu Jul 18, 2024 7:24 pm | |
| A few points to be clear, only the LH lever "Limit Switch" with the connectors/spades facing aft is part of the starting circuit, the switch spades facing in are for brake lights only, IOW only the LH lever affects cranking. Both the "Limit Switch" and "Side-Stand Switch" must close/work to crank scooter, see attached diagram. The simple way to check your starter, is to jump across big terminals on starter relay, engine should turn regardless/irregardless ![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png) of key position, etc., you're powering starter directly, best to check with key off. see pic. Lastly this video kinda shows where starter is, not easy access ![Shocked](https://2img.net/i/fa/i/smiles/icon_eek.gif) https://www.youtube.com/watch?v=NmEReZcaScQ ![bike won't start after turning it on and off Sw7410](https://i.servimg.com/u/f71/20/30/67/46/sw7410.png) ![bike won't start after turning it on and off Starte12](https://i.servimg.com/u/f71/20/30/67/46/starte12.jpg) |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Thu Jul 18, 2024 7:40 pm | |
| I saw the video up there before and I stripped the bike down like 90% and still didn't see it. I'll really have to rebuild this thing aren't I? |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Thu Jul 18, 2024 7:44 pm | |
| Kinda remembered one of your other post on corroding side stand, maybe check/clean frame multiple wire ground point, behind LH aft cover |
![bike won't start after turning it on and off Empty](https://2img.net/i/empty.gif) | Subject: Re: bike won't start after turning it on and off Fri Jul 19, 2024 4:07 pm | |
| Hi XDM.
Sorry I should have said ignition coil, it's what makes your plugs spark, would be a good idea to clean the rusty connection where its bolted to the mounting bracket, the coil body (not the connection wires) needs a good earth/ground.
Could be a reason why no fire up.
Hope this helps |
