| front wheel balance weights | |
+4KurtPerthWA john grinsel Winger61 john&lesley 8 posters |
john&lesley Scooter Rider
Number of posts : 50 Location : bristol uk Points : 3937 Registration date : 2014-03-29
| Subject: front wheel balance weights Wed Apr 09, 2014 11:04 am | |
| Can anyone else tell me if their front wheel has been balanced mine has 2 long strips about 10 of those squares on each side of the wheel and the are not even opposite each other why so much balancing .I take one hand of the handle bars at any less than 30 mph and get a hell of a shake .as you know ive just renewed the fork internals with all new parts and running 29 psi in the front avon viper tyre also 20w oil in forks .my question is does the front wheel have to be balanced at all my wheel bearings are fine to cheers all |
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5599 Registration date : 2010-10-16
| Subject: Re: front wheel balance weights Wed Apr 09, 2014 12:24 pm | |
| I run PunctureSafe in my tyres, and it seems to make a difference - no vibration/wobbling. Might be worth a try. Also, I've never tried Avon Viper tyres, but some comments posted on www.Maxi-Muppets.co.uk would suggest they are not good tyres. You could always have a look on there, join up and do a search for Avon Viper. Just a thought.
| Subject: Re: front wheel balance weights Wed Apr 09, 2014 1:09 pm | |
| Tire and wheel assembly needs to be balanced each time tire is changed---and sometimes more.
I use "Ride On" Do not know if available in your market. Those squares on wheel are wheel weights, stick on.
"Head shake" first look at steering head bearings and their proper adjustment. Take wheel out, have bike shop balance, also.
If "Ride On" or similar is found----remove those stick on weights!
t
KurtPerthWA Silver Wing Guru
Number of posts : 1711 Age : 75 Location : Belmont, Perth WA Points : 8123 Registration date : 2009-01-19
| Subject: Re: front wheel balance weights Wed Apr 09, 2014 1:26 pm | |
| Mine does the same on OEM tyres (14000klm). Its the tyre wearing under braking or lack of pressure and low speed maneuvering combined with the fork trail. The rubber scallops out around the tread ribs. It is common, not only a Silverwing problem. Sit on the bike and move the handlebars side to side. That lateral movement is what I am talking about.
Don't forget to check the OEM Playdoh wheel bearings too. |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4775 Registration date : 2012-06-15
| Subject: Re: front wheel balance weights Wed Apr 09, 2014 2:16 pm | |
| It sounds like someone used a lot of weight to balance the wheel, if your description is accurate. Are you saying they used 10 balance weights on each side of the wheel? That does sound like lot more than I would expect it to need. |
| Subject: Re: front wheel balance weights Wed Apr 09, 2014 3:14 pm | |
| Yes a strip of 10 each side of the wheel they are not even ajacent to each other |
| Subject: Re: front wheel balance weights Wed Apr 09, 2014 6:03 pm | |
| 60grams on each side I have just this moment unpeeled them they look like the strips you can buy on ebay.I have jacked her up on no play in wheel bearings or head bearings so will take her to work tomorrow and see if what I done helps |
Number of posts : 2615 Age : 72 Location : Bullhead City, AZ Points : 7470 Registration date : 2012-05-17
| Subject: Re: front wheel balance weights Thu Apr 10, 2014 1:24 pm | |
| 20W fork oil? Is that what is suggested? Most Honda's (including my Goldwing) want 10W or lower. |
| Subject: Re: front wheel balance weights Thu Apr 10, 2014 1:29 pm | |
| Carring around 200kgs two up so didnt want to much dive |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 4990 Registration date : 2012-01-19
| Subject: Re: front wheel balance weights Fri Apr 11, 2014 2:43 am | |
| - GHM-PM wrote:
- 20W fork oil? Is that what is suggested? Most Honda's (including my Goldwing) want 10W or lower.
The Progressive springs for the Swing come with 20w fork oil. |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8363 Registration date : 2009-07-18
| Subject: Re: front wheel balance weights Fri Apr 11, 2014 4:48 am | |
| Exact weight of fork oil pretty much depends on how you ride a bike. I used 10W fork oil in my GW with Progressive springs. It really depends on your weight and the bike as well as the total load you most often carry. I've really never had a fork bottom out, some rear shocks on old bikes but not often a fork so it makes sense to me to adjust the oil viscosity to the ride you want. What may be good to reduce diving in the summer may be like riding with a solid, unsprung fork in the winter. |
